I replaced my AOS a few days ago, while doing so I removed the intake on the drivers side. I noticed a LOT (IMO) of black build up on the walls of the intake as it heads to the valves. Also "some" in the upper intake, but not near as much.
I thought about cleaning what I could manually, then thought... I dont think having one side clean, and the other side not clean was a good idea ? (ballance) plus didn't want to risk haviing some large piece drop into the combustion chamber and do who knows what.. So I buttoned it up (new gaskets and clean surfaces of coarse) and she is running fine...
Now I am thinking... is there a way to clean all 6 of those?, am I loosing power? causing poor air mixing? .... blah blah blah...
So anyone have any suggestions?
99 C2 108k miles, runs premium Shell gas, oils change up to date, car runs on regular trips long enough to warm up, no other issues at this time
I wouldn't worry about it. The gunk seems to stick to the intake and never comes loose without some help. It won't affect mixture.
