Anyone know if Porsche sells the oil filter wrench, that is required to remove the plastic oil filter cover now located in the engine bay? I would like to know if it came in the aluminum metal as did the 996 ones that they sold at the dealer.
Yes, I bought mine from a Porsche dealer.
Loren do you have the part number for the new filter wrench or know the size hex needed to remove the filter.
http://www.renntech.org/forums/index.php?s...entry1823
Current dealer MSRP is: $35.68
Loren, I have that oil filter wrench for the 996 and others, but the new design for the 2009 facelift 997's have a larger oil filter housing and also the hex mold on it, like the ones you find on BMW's the 996 oil filter wrench will not fit.
Being that this is a 997.2 forum... i believe the plastic filter housing is a 36mm. i bought a 36mm axle socket at my local pep boys for $9 and it works like a charm with my torque wrench.
