Loren, et al.
I have a 2000 C2 Coupe that's been problem-free, until now....
I am unable to open the driver's side door from the outside. Opening from the inside is not a problem. There seems to be no problem with the multi-stage locking wedge (not stuck in up/down position). All locking mechanisms work well.
Therefore, I'm pretty convinced there's something wrong with the actuating shaft within the door handle...perhaps the retaining pin dislodged or a circlip popped off? It sounds like there is a small part freely rattling within the door casing.
Any experience or suggestions with this problem you might be able to share? Also, any complete instructions & schematics on disassembling the door handle would be appreciated.
Thanks in advance.
