Hi
Is there someone who knows how to proceed to bypass the folding roof safety ?
I 'm knowing there is a special relay existing but very expensive...Nothing about a small tip ??? :P
Just to avoid an emergency stop when it's begin to rain.... B) B)
thanks
Hi
thanks
There is a plunger switch in the center console that is pressed shut when you raise the parking brake a few clicks. The switch has a two line wire that plugs into it. You could unplug that and jump it, but then your dash readout would say your parking brake is on all the time. I supposed you could rig something up with a different type of manual switch that you close when you want to open/close the top.
