I can't see why there would be any difference. The C4S has the wide body effect, but only to accomondate the wider rear tires and the big brakes. I would not think that Porsche would go to all that trouble to make two different sway bars for a stock non-racing/track car (ie GT3). You could check the parts houses and compare sway bar specs or codes to see if they are the same.
