Hi, there,
Does any know the part number of the standard suspension for a 997 Carerra S?
Various types of factory suspensions:
1. Standard suspension (non-PASM) - this is the one I am looking at
2. Standard PASM set - not the one I am looking at
3. -20mm Sport Suspension (non-PASM) - not the one I am looking at
Basic info of my 997:
MY05
C2 Coupe
6-speed
Country: RoW (Hong Kong, RHD)
Your help is appreciated! Thanks in advance!
wheel carrier
control arm
wheel hub
1 997 331 111 06 wheel carrier /L 1
(1) 997 331 112 06 wheel carrier /R 1
2 999 053 055 02 angular-contact bearing 2
3 996 331 661 01 cover 2
4 999 217 042 09 hexagon-head bolt
M 8 X 35
8
5 997 606 407 01 speed sensor 2
6 900 067 117 09 pan-head screw
M 6 X 16
2
7 997 331 605 00 wheel hub 2
(8) 996 331 047 06 control arm 2
9 999 084 445 09 hexagon nut
M 12 X 1,5
4
10 900 378 138 09 hexagon-head bolt
M 12 X 70
4
11 900 378 165 09 hexagon-head bolt
M 12 X 95
4
12 999 084 445 09 hexagon nut
M 12 X 1,5
10
13 996 331 045 12 track rod 05 2
(13) N 997 331 045 04 track rod 06- 2
14 999 084 449 09 hexagon nut
M 12 X 1,5
4
15 996 331 217 02 eccentric screw
M 12 X 83
2
16 996 331 219 00 eccentric washer 2
17 996 341 043 06 control arm 2
18 900 378 051 09 hexagon-head bolt
M 14 X 100
2
19 900 380 012 09 hexagon nut
M 14 X 1,5
20 900 378 135 09 hexagon-head bolt
M 14 X 75
2
21 996 341 053 17 control arm 2
22 996 331 217 03 eccentric screw 2
23 997 331 483 01 lining
control arm
05 2
24 997 331 485 00 lining
control arm
05 2
Here is some numbers for the rear suspension. Call Susnset Imports. They
are the best!!!
Paul
Thanks Paul!
Are there any numbers just relating to the shock absorbers and springs for the rear in the list you posted above?
Thanks again!
shock absorber
coil spring
(1) 997 333 051 11 shock absorber 2 I029
COUPE/CABRIO
CARRERA 2
(1) 997 333 053 20 shock absorber 2 I475
COUPE/CABRIO
CARRERA 2
CARRERA 2-S
mount
shock absorber
- 900 378 138 09 hexagon-head bolt
M 12 X 1,5 X 70
2
- 999 084 445 09 hexagon nut
M 12 X 1,5
2
2 997 333 061 00 supporting mount 2 I029
COUPE
(2) 997 333 061 01 supporting mount 2 I475
COUPE
CARRERA 2
(2) 997 333 061 03 supporting mount 2 I029
CABRIO
CARRERA 2
COUPE
CARRERA 2-S
(2) 997 333 061 02 supporting mount 2 I029
CABRIO
CARRERA 2
(2) 997 333 061 02 supporting mount 2 I475
CABRIO
CARRERA 2
CARRERA 2-S
(2) P 997 333 061 00 supporting mount 2 CARRERA 4
COUPE
I029
(2) P 997 333 061 01 supporting mount 2 CARRERA 4
CARRERA 4-S
COUPE
I475
(2) P 997 333 061 02 supporting mount 2 CARRERA 4
CARRERA 4-S
CABRIO
I475
(2) P 997 333 061 03 supporting mount 2 CARRERA 4
CABRIO
I029
- 900 380 008 09 hexagon nut
M 10
6
3 996 333 511 02 compensating plate
0,5 MM
X
(3) 996 333 511 03 compensating plate
4,0 MM
X
4 993 333 504 00 ring 2
5 999 152 163 00 snap ring
SW 52
2
CARRERA 2
(6) 997 333 531 37 coil spring
1 set
1 I029
COUPE
504 marked
violet
white
CARRERA 2
(6) 997 333 531 39 coil spring
1 set
1 I029/I480
CABRIO
504 marked
violet
yellow
CARRERA 2
(6) 997 333 531 43 coil spring
1 set
1 I475
COUPE
504 marked
red
yellow
CARRERA 2
CARRERA 2-S
(6) 997 333 531 45 coil spring
1 set
1 I475
CABRIO
504 marked
blue
yellow
CARRERA 2
I475
CABRIO
CARRERA 2-S
(6) 997 333 531 48 coil spring
1 set
1 I029/I249
CABRIO
504 marked
violet
yellow
CARRERA 2
7 993 333 107 01 bellows 2
8 996 333 105 02 additional spring 2 I029
(8) 997 333 105 01 additional spring 2 I475
9 999 084 050 02 hexagon nut
M 12 X 1
2
10 999 025 271 02 washer 2
mount
shock absorber
M 12 X 1,5 X 70
2
M 12 X 1,5
2
11 997 618 105 04 control unit
shock absorber
05 1 CARRERA 2
CARRERA 2-S
I475
(11) N 997 618 105 05 control unit
shock absorber
06- 1 CARRERA 2
CARRERA 2-S
I475
(11) N 997 618 115 03 control unit
shock absorber
06- 1 CARRERA 4
CARRERA 4-S
I475
- 997 618 205 00 support
for
control unit
1
12 997 333 513 00 concave washer 2 I029
I475
13 997 333 523 00 concave washer 2 I030
14 997 333 513 01 concave washer 2 I030
- -- E N D
Here you go.
Paul
