Hi to all :-)
i m from Germany, Munich, Bavaria and i did a complete PCM 2 retrofit in an Boxster built 5/01.
I changed the Instrument Cluster to an 04´IK. everything work fine, even the Audio Information in the DOT Main Display. I took the CAN Comfort from the ClimateControl Unit.
So everything work,.. but one Question is left, maybe you can help me.
What is the Connection to the Socket C4?
C1 and C2 is Can High and Low - clear,.. but C4? is it connectet to the VS90 for the OBD Diagnosis?
Thank you very much,
Kind Regards
Kai
