Does nayone know how to get the "s" button to work once you have changed the AUX over to On ? As i plug in my ipod I hold down the "S" button i should recognise it but it doesn't any ideas?
Nigel615
You should just push it once, and the display will say FM1, CD, or AUX. It just cycles through with each push. Make sure AUX is activated in the setup because otherwise it will just switch between CD and FM.
Plug in your iPod and then click it until AUX appears on the screen. Then you should be good to go.
