I started my car after i just went to get coffee, it started fine and when I shifted it on reverse it started acting up and the car died it won't start again. I checked the gas and it still has 59miles to go. I thought it was the gas so i put 2 gallons and it still won't start. I put gas on the trottle and it started. Would this be the fuel pump. How could I test if the fuel pump is working and I did checked the fuse and it's okey. Don't know where the relay is located and the manual says relays should be replaced by authorized technicians only. The price of the Fuel Pump from the dealer is $490 and I would like to make sure that would be the problem if I replace it.
Charles
2003 Carrera C2 104k miles
My fuel pump failed in the exact same way less than two months ago. I'm glad you only have 3 gallons of fuel. I had the burning privilege of getting elbow deep in 11 gallons myself. I've replaced many 996/986 fuel pumps but mine was unbelievably stubborn. Don't be surprised if it's VERY stuck should it turn out to be the problem.
sounds like the fuel pump or a ruptured fuel line...
I had the wheels balanced is it possible that they could have pinched the lines while jacking it up?
