ok well ive checked the runners and all is well and not loose.... when you accelorate it the back of the seat seems to click back like its giving way by a few mill enought to feel have searched and dont see anything like this but wondered is it an issue with the seat design its self, something worn under the leather ??? its very anoying it feels like a loose runner but its not it doesnt even move when you grab seat and jiggle it just kinda pops back when your sitting in it....
car has done 73k 1999 cab seat not worn or signs of fat PO im 13 stone so not a lard arse either.... right foots a bit heavy but eh its a porsche !!!!!
look forward to hearin from yah
any ideas should i take seat apart is that easy..... i thought i read somewhere about this happening on a site might not be here... any help appreciated please how to take seat apart plan ???
what happens after your seat is clicked back? Does it come forward a bit then clicks back when U accelorate?
How did U inspect it? Are those 4 mounting bolts tight?
It is easy to remove your seat(5minutes). just be careful not to trigger the airbag light, I usually leave my wiring hradness intact. Also protect your door sill
I would remove then inspect the railing.
I had some play in the height adjustment arms and bushes on the sports seats in my C2 which gave a clicking noise, especially when I got in and out of the car. The bushes are nylon, and two of them were very badly worn. You have to buy the bolt and bush together, as they aren't sold separately. The front and rear boltt+bush are different, and there is a radical difference in price. One is cheap, and the other is VERY expensive. I also bought the two short swing arms, as they were very cheap - I didn't want to have to do the job twice. Not a difficult DIY. Items 4 and 10 in the diagram.
ah thanks guys something to go on.... its not the base that moves feels like the back and not the hole back feels more like the padding clicking into place but may be the assembly bolts ill have a better look this weekend and see what i discover
very many thanks
  • 2 months later...
