The self adjustment of the litronic lights in my 2002 Boxter has stopped working. Neither light adjusts at ignition on, and neither dipped beam raises slightly to support the high beam. It sounds like the motors are running to adjust the lights, but there's no movement.
I've swapped the entire headlight unit with another car with litronics, and the behaviour follows the headlights. The known working units are fully working in my car, and my lights don't self adjust in the other car.
I've found a few references to internal gimbals jumping out - does anyone have more information or pictures of this part of the headlight assembly? I've partially dis-assembled one of the headlights, and the unit / reflector assembly seems quite solid and doesn't move around in the housing.
