Whenever it rains, water collects somewhere behind the headrests (mostly behind the passenger seat). While driving, I can hear how it runs back & forth behind the driver's seat and the passenger seat -- sounding like it's an inch deep. Since this is something that happened quite recently, I suspect there might be some drainage that's clogged. Any help appreciated, (it's a Box '98).
-- peer
Hi Peer,
Put your top in service position, remove your rear storage compartment and then your engine cover and check your engine compartment's drain tubes. It sounds like you have water in the collection trough that collects water and funnels it to the drain tubes. Search this site and you will find lots of information on drain tubes. Good luck!
