My trunk light is not working ( properly ), if i open the trunk the light stays off IF i open the engine compartment the light in the trunk goes on !
If i open the trunk and close the car there is no beep but if open the engine compartment and close the car there is a beep.
So what can it be ?
Thanks !!
Looks like the micro switch in the trunk lock is faulty, this is common. The switch is available separately. Do a search on the board here for DIY.
