My CDR-220 model BE 4462 from my 2000 Boxster has an issue whereby the cd's wont play any longer. I get "loading" and then "error" message on the screen. I tried numerous cd's. I suspect that means there is a major problem. Radio and remote 6 disc changer work fine. Someone locally is selling a CDR-220 BE 6625 part number 996.645.126.10. He says it works fine. I have two questions....first, am I correct that the error message I'm getting means the unit is fried for playing cd's and is not worth fixing? Second, will this CDR-220 (BE 6625) from a 996 plug right in play without modifications if I swap them out? The BE6625 does have a code key with it. Why the different model numbers? I can understand different part numbers because they're from different cars, but why different Becker model numbers? Would there be differences in wiring harnesses, or something? If anyone has had any experience regarding interchangeability, I'd really appreciate your input. I need to buy in next day or two, or let it go. Thanks.
