Hello there!
I know this topic's been discussed before and I have read some thigns about but with no success :(.
I own a Carrera 4s 09/2002 equipped with a Becker cdr-23 with no CD charger. All I need is a aux-in in order to listen some music from my mobile telephone.
I have read I could use the cd charger line to do that, is it right?
Thanks in advance.
Hello there!
Thanks in advance.
Yes, there is a Becker kit for about $25 dollars that will allow for an Aux input. There are simply settings that enable the Aux input. Do a search and you will find all the info you need.
CDR-23 is MOST bus; I thought there was no aux input possible, and the only way to get external input was via an FM transmitter?
Hello there!
Thanks in advance.
Oh... I also have a BOSE sound system! I have read this configuration (w/ BOSE) means optic fibre MOST. If so would anything will change?
I tried the Aux kits with the CDR-23 and they didn't work. I ended up replacing my head-unit and amplifier.
