1996.996 coupe.
Any ideas on these P-codes,and what the fix might be?
P-1691
P-341
Car failed e check and CEL bulb has been replaced but does not illuminate on start up.
Re- P341,the camshaft sensor has been replaced.
Thanks Jeremy.
P341 - Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+
Most likely causes: No power supply, Short circuit to ground, CMP sensor faulty.
P1691 - Check Engine Malfunction Indication light (MIL) - Open Circuit
Most likely cause broken/disconnected wire. Check the connection at the DME and Instrument Cluster.
You may want unplug and re-plugin the large cable for the DME since both faults point to "no connection" (disconnect the battery first to be safe).
