I will do a spark plug job over next weekend on my 03 Boxster 2.7.
Did buy six Beru Ultra 14FGR-6KQU with 0.7mm gap.
Any body can confirm what is the needed gap for my car or if I stays with BERU factory gap?
Tks!
Thierry
Tks!
Thierry
Are you sure you measured correctly? Beru's are usually pre-gapped.
Spec on the 2.7 liter engine is: 1.6 mm + 0.05 mm
Loren, you're absolutely right. I guess the 0.7 mm written on the box is the distance between a ground electrode and insulator.
But I did mesure the distance between a ground electrode and the the center electrode and it's around 1.6 mm
Thierry
