Is there a part # for the socket that plugs into the dash switches ie the spoiler, footwell switches etc?
I don't want the wiring harness just the plug/socket thingy.
It's the receptacle that the dash switches plug into.
The thing that holds the wires.
Like when you remove a switch, it's the plastic thing that you pull off of the switch.
I want some so I can make my own wiring harnesses for dash switches.
Edited by Foster
Foster, here is a diagram of the dashboard trim from the PET, one is -01, the other 02-. Post the # of the part you are looking for. If it is #19 or 21 post the interior colour as well.
Alex
The pink, yellow, and, green plugs.
Do they have a part #?
Edited by Foster
  • Like 1
The complete wiring harness sections do, but the plugs don't. If you want just the plugs you'll have to talk to a service technician not the parts department. They have wiring repair kits with all the different type plugs.
Foster, the switches are not Porsche parts, look on the switches for a Audi/VW P/N, then google the number and I'm sure you can find a parts supplier online that sells them.
Alex
If you look in the post where the pic is from, you'll find the part numbers. --Brian
