Hey Guys, I need some help diagnosing an issue im having with my 97 Boxster.
One day, Im driving 65MPH on the freeway when I hear what sounds like a handgun being fired from inside my engine compartment... The engine didnt hickup or anything but once I was off the freeway the Idle was alittle unstable, moving from 900 - 1100rpm's and I got a CEL with 1 code (P0441 Fuel Tank Ventilation System - Above Limit )
She sometimes stalls during idle and will take about 7 seconds of cranking to start back up & sometimes comes close but doesnt stall.
Also, when I turn off the engine after about 10min drive I'll hear a sound similar to a low toned 1 second honk coming from either the passenger front Fender or engine bay... Hard to tell, really.
Any ideas what would cause all these symptoms?
I would check for oil in coolant.....
Also check compression on each cylinder.
does your temperature gauge rise?
check your water pump to make sure the pulley is still there.
m
m
Sorry, No im not having any cooling issues what so ever... This problem is related to vacum and Emissions components. All my cooling system components are there and working.
Figured it out...
I hooked my Boxster up to our shops Durametric software and ran the Drive Links section and activated the Fuel Evap Valve and sure enough I couldnt hear it click on & off like it should once the durametric software tries to activate it. So I gave it afew hard taps with the knob of a screwdriver and sure enough it started clicking on & off and the honking went away... Part number is 996.110.129.05 circled in RED
Dude!
You're good. B)
Thanks! :cheers:
I just hope this helps any other forum members that suffer from this condition. E.D. is a very serious condit.... Wait I meant F.E.V.F.! (Fuel Evap Valve Failure) ;)
Edited by CJ_Boxster
