After reading a few articles on a Cayman forum, I was wondering if it is possible to buy an underdrive pulley for a 3.6l 996 or if anyone has fitted one to their car?
Why not they share the same pulley!
I knew a bunch of guys who put them on Mustangs to supposedly reduce the load of the alternator, A/C & smog pump. They don't do much except make it hard for your car to idle because the alternator isn't putting out enough juice. You'd be better off just removing the A/C.
I thought about pulling the trigger on the pulley for my 3.4L 996. The main reason being to protect my power steering pump from track use. Thankfully overheating the PS pump on 996's seems to be less of an issue than it is on the cayman.
They're much easier to install on the 996 than it is on the Cayman if that sways your decision any.
