Yes you can, E-Gas engines have only one electric connector on the throttle body and no cable. ROW 3.2 litre engines are E-Gas.
Ah, I wondered about that...
Doesn't the Tip have a cable? I thought my 2.7 2000 tip was an e-gas and its got a cable.
There is no steel cable on the E-Gas throttle body, Tiptronic or manual. Some early MY's have a short steel cable from the accelerator pedal to the pedal possition sensors.
