I recently purchase a 03 996 C2 6 speed with 20K miles. After only driving a few hundred miles i noticed the oil pressure guage wandering around slightly during normal highway speed. Is this normal? Thank you.
The reading will change with RPM and temperature, is this what you are referring to? Any idea as to the weight of engine oil being used?
0W-40 Mobil 1, the guage is only fluexating slightly but when im running steady at speed and at operating tempature.
Anthony,
I have an MY02 C2 that has the same symptoms....generally with the oil pressure in the 3 to 4.5 bar range. The oil pressure transmittters have been known to fail. And, because the connectors (oil pressure gauge / oil pressure idiot light) on the oil pressure transmitter are not protected from the engine compartment elements, a poor connection could be the cause of the fluctuating oil pressure indication.
Because my oil pressure only fluctuates when the oil pressure is running in a certain range, I'm thinking my problem is in the oil pressure transmitter itself. MSRP at a dealer is about $50-55 and is supposed to be owner replaceable....if you have long skinny arms.
Bill
