it sounds like there is knocking right under the plastic cover which says 4.5 and also there is constant knocking coming from the bottom of the engine----tuck--tuck--tuck---tuck---tuck----the sound can be heard from the wheel wells while suv is idling---could it be bad coils---
There is a post somewhere in the Cayenne forum by member gunzie, i cant find it for the moment, who have had probably the same symptoms as your car, please do a search.
Noise 1: see post 3.
Noise 2: could be the water pump.
thanks for your reply--i am booked in for service on monday---i still have 400kms left under warranty---hopefully they will not say it is normal
I don't think that they are going to say it's normal, the engine sounds like a concrete mixer driven by an old diesel motor. Hope the best for you next Monday and rapport back please.
yes, i will definately report back
plus
i just took a look at the coils and they are all cracked---could this be causing problems-----
ps::i am starting a new question about this problem
Hey Bro, listening to the video it sounds like U may have some people stuck in ur engine......... may be the 1st problem!! Do u have any coolant leaking? That would be #1 for a water pump I would think. I had similar noise, but I also had coolant all over the place, may be ur water pump starting to go. I had about an inch of lateral movement in mine.....whoops
Good luck!
Good luck!
could it be the coils
Good luck!
If it were coils he would a CEL and many faults.
update---took the car into the dealer
coils cracked--replaced--tech says all noises are ok-------
service advisor listens and agrees there are noises and tech is wrong-----
service manager is called---right away hears the sound---orders a bore inspection and advised of possible engine replacement under warranty----
will keep you posted if it turns out to be something else----
