Does anyone know if you can replace the standard 987 heat/air unit ( No. 99765310109), with a climate control unit (No. 99765311109FMH). The units are the same size and almost identical and it appears the wiring harness is compatible. So my question is can you just upgrade to a climate control unit by just replacing the "head unit"?
The latter one includes seat heating and the previous number does not.
thanks Loren, so then what is the part no. for the standard manual a/c unit with heated seats? is it 99765311310FMH ?
Manual A/C only and heated seats.
For 987's to MY07 it is: 997.653.113.12.FMH
For 987's MY08 on it is: 997.653.113.13.FMH
Sorry, I do not know the difference.
Till MY 07 button lettering = ECO // MY 08 button lettering = OFF that's all.
  • 9 months later...
Sorry to resurrect this old thread. Do you guys know if this is really plug & play? I have an '08 987s w/heated seats that I factory ordered. My only regret is not getting climate control.
Any guess as to the cost of the control unit?
Thanks all,
Scott.
Thanks all,
Scott.
Part Number change -- For 987's MY08 on it is: 997.653.113.14.FMH
MSRP $669.78
Thanks all,
Scott.
MSRP $669.78
Wow, that was fast. Thanks Loren!
Any guess as to whether or not it's plug & play? I'm hoping there isn't a different harness, or some fact-intalled-temp-sensor up in the dash that I'm missing.
Thanks again,
Scott.
Thanks all,
Scott.
MSRP $669.78
Thanks again,
Scott.
Even if it is plug 'n play you might also need a PIWIS to turn the functions on and set country codes. Not sure though - never tried it.
