Mine is. 99 C2. The front hood takes a very firm press to latch it.
I'm sure the latch can be adjusted, but I haven't bothered.
I have a Boxster, but I think the front hoods are pretty similar. There are two rubber pads, one on each front corner of the hood itself; these can be adjusted just by turning them like a screw. Screwing them in a little farther may make it easier to latch. Just make sure you don't shorten these pads so much that the hood can rattle over bumpy roads.
Edited by secretagent214
Same here, hard to close. I also have to push hard on the Porsche crest like you mention...
If you continue to push on the Porsche crest - it will break and fall off.
Push on the paint near the front edge of the hood.
AAAAAHHHHHHHHHHHH!!!!!!!!!!!!!!!! Dirty hand prints!!!
I guess they are cheaper than a new crest, but I hate hand prints on my car!!!
Same thing on the TT....I usually end up puttng my palm down on the front edge, then putting my other hand on top of the other and pushing down till I hear the click. It usually does take some pretty good downward pressure.
