Okay all, I have searched in here, Rennlist and 6speedonline for various muffler hack versions. Most that I have seen use new tubing to connect either the muffler "box" to the outlet, or the inlet directly to the outlet, or both. My question is has anyone cut open the side of the box and modified the internal cavity any? One of the negatives of the stock mufflers is their weight. So if you do a little cutting and remove some of the internal you might "very slightly" reduce it instead of adding more with more tubing. I was thinking of either sending my stock units to FisterD for his Stage II mod or just trying it myself since I have a MIG welder. However, finding the right tubing in stainless steel is a little challenge even though some have posted good resources for them. Guess my point is for virtually no investment I can modify the internals and should achieve similar results to the "hacked" mufflers.
Anyone done this
