Had to take battery off to charge (didnt realize it also drunk almost 1L of water in 18 months).
1. Put battery back and could not find setting for date neither on PCM nor on board computer. went through the manual where it says how to change time and format for the date but nothing about changing date itself. Silly question, what am i missing? searched this forum but found nothing about this. Is this a PIWIS job?
2. Is the issue of changing battery with less than 1/3 of fuel been fixed for C4 from 2003 onwards?
PIWIS have the possibility to change the date, however in normal situations the PCM will pick up the date as default, after you let sit the car in the open air. I would fill up the tank to full, and look what the fuel gauge do, to be sure.
The same thing is happening to my 03 C4S. Take a look at the 996 TSBs. The very last one on the last page is the one you want (part id 18/03, number 9110).
Basically the time is set automatically in the PCM2 and instrument cluster if the GPS almanac is loaded. The GPS almanac is not available after disconnecting of the battery and must be reloaded. To load the GPS almanac, park the car outside (or where it can get good satellite reception) for about 30 minutes with the ignition key removed and the PCM2 switched on. The GPS almanac should load within this time period. The instrument cluster should also automatically adopt the time from the PCM2.
My car had the wrong date and time. The date eventually re-set itself and now it reads the right date. The time still defaults to 4pm. The problem I have is that I do not have the Navigation discs and I think they may need to be loaded. Anyway, please let me know if this process works for you.
Oscar
I tried leaving the car outside for 1/2 hour with the PCM2 on and the key off the ignition and still nothing happened. Then I when back in the garage and smashed some things. That made me feel a bit better, so I decided to pull the PCM out to see why the GPS was not getting any signal (it was showing 0 satellites all the time). Well, the GPS antenna was not connected! Reconnected the little bugger and left the car out for about 10 minutes. The time and date are working great now! I also went to the dealer and picked up the 2008 map retrofit kit ($299) so everything is working as it should.
Hope this helps fixing yours.
Oscar
  • 11 years later...
Just purchased a 2003 911 Carrera the time is fine the date is incorrect and can’t find any info on how to set the date… Any suggestions??
