I am so upset, I was in a parking lot and because of a glare did not see a curb which I went over on my front left. As I parked 5min later I saw a stream of yellow oily liquid coming out of the rear right. I am so bumped. Any idea what it is and how big of a deal we are talking about?
thanks!
thanks!
WOW....You must have hit that curb pretty hard....it seems like you have scared the ***** outta her!
thanks!
You need to find out what is leaking and where.
If you do not feel comfortable doing it yourself then take the car to a good Porsche shop.
Try parking it with the nose facing down hill and see if you don't see what sounds to me like the wrong type of coolant leaking from the radiator located on the corner you hit the curb. I once ran over something possibly furry and most likely hard that damaged my radiator. However when I parked slightly up hill I saw orange coolant leaking from the back of the car near my rear passenger tire. Upon closer inspection I discovered it to be the drivers side radiator that had bee damaged and I believe was causing an overflow in the res. tank. Someone correct me if I'm wrong. Still learning. :renntech:
Firstly, it sounds like you have regular coolant and not Porsche's special coolant in your car. (Or, your car is the Alien. LOLOL!!)
Secondly, it sound like either you damaged a radiator or a hose. Time for the Shop....... not so funny.
