Boxster Doug here from California....
Went to take a ride the other day and the drivers door would not open from the inside or outside! The passenger door works fine along with the lids. Short of doing a James Bond entry over the door I am at a loss.
The remote sounds like it is engaging the door actuator. The horn gives me two short honks telling me the the system is not right. The key works fine, turns both ways, but nothing.
Has anybody ever had this happen or have any recommendations. Most of the dealers say they have never had such a problem.
Does any body know if there is some kind of manual over ride.
Help ! Help!
:welcome:
Have you tried unlocking the door with your mechanical key?
Yes, same result as when I use the remote. Two short horn honks and nothing. I can hear the actuator engaging, bot nothing.
