Just been told by the local tire guy that my rear wheel is bent. I have the 18" Carrera wheels, option M411, tire size 285/30R18 do I have the 11 or 10" wheels? Can't seem to wade through all the posts even with a restricted search.
Many OEM Porsche wheels have the offset and width cast into them near the valve stem. I'd check there for a start. (they are probably 10's).
Of course it all depends on what model is your P-car. I believe, If you have the normal rear body, then it would be the 10inch, if you have a wide-body (turbo, C4S, GT2 or GT3) then it would be the 11 inch.
