The outside edge of my rear wheel are getting worn much faster then the middle and inside. I'm assuming this is camber/alignment. Do I have to take the car to my porsche dealer or can firestone etc align the car also?
Edited by bnewport
  • 2 months later...
993s tend to wear their rear tires like that too. It might have to do with the kinematic rear suspension that adds toe in during off throttle conditions.
Theoretically just about anyone can align the car. You may want to ask if they have a Hunter machine to do the alignment with. If there are any porsche specific independent shops in your area see who they recommend. A competent shop should charge $100-200 for a 4 wheel alignment. They should be able to tell you exactly what your current alignment is and what they adjusted it to. The Hunter machine gives a printout of all the relevant numbers, will measure toe to less than 1/32" accuracy and camber to less than 1/10 of a degree.
