So far, over the past year, my car has had the following work done:
New Airbag ECU
Front and rear CV Boots
6 new tyres
2x high flow manifolds fitted
Mass Air Flow Sensor replaced
1x rear brake light
2x front light bulbs
New clutch
1x windscreen chip repaired
Work outstanding:
DME reprogrammed
Rear window repaired/replaced (split)
great car...high maintenance!
Yes, It can be especially expensive to replace front cv boots.
P.K.
Yeah, I guess you have to convert it to AWD, so you can replace the CV boots.
I don't believe these cars to be high maintenance but they tend to be expensive to fix. Most what you listed is normal wear and tear.
I guess I am comparing it to my old "normal" car...maybe one thing a year! But, yes, have noticed the expensive bit a few times!! lol
I bought a poorly maintained '98 with a blown engine. Dropped in a used replacement with new O2 sensors, AOS, and spark plugs. And that's the extent of maintenance. I realize this isn't fair comparison, but now that I'm familiar with the car, I expect maintenance to be quite manageable. One has to look at Porsche as exceptionally designed, engineered, and manufactured true sports cars for public use. And because they're sports cars, when used as designed, require a different measure of maintenance from cars desgined to be driven and ignored. I also have three 928's which are often maligned for their maintence. I've found that if sorted out properly, they give far superior performance and reliability than most cars and do it applying very reasonable level and cost of maintenance.
I must admit, mine is now due new air filter, fuel filter, oil filter, oil change and spark plugs...
New Airbag ECU
6 new tyres
1x rear brake light
New clutch
Work outstanding:
DME reprogrammed
Six (6) new tires...I'm assuming two sets in the rear and one set in the front? How miles did you put on the vehicle over the past year? I've got an '03 (non S) with 138,400 and other than the bulbs and regular maintenance, I haven't had to do anything. I'm still running hard on the original clutch. I drive a mountain pass each day and drive hard...my tires have been pretty good too. ;)
Best car I've ever owned.
All the best,
Bill B)
New Airbag ECU
6 new tyres
1x rear brake light
New clutch
Work outstanding:
DME reprogrammed
All the best,
Bill B)
Yes, was 1 set for front and 2 for rear...the S really rockets and i guess I drive too hard! lol I have done about 10000 miles in past 12 months...
Edited by Elliottc26
Intake manifolds, or exhaust manifolds? And were those "maintenance" items, or upgrades?
Why does the DME need to be reprogrammed?
Edited by Banana S
Exhaust manifolds...needed replacing so upgraded to high-flow stainless steel...
Thought MAF was new style, turns out was old style...
All the work I have had done has been maintenance...would also like alloy wheels refurbished (look knackered!) and am having new 02 sensor installed (again needed as one of mine is duff)...MOT due in April...also have air filter en route...
