picking up my wheel spacers today
got longer lug bolts, but i hear i need to remove the "collars from the old bolts and reuse them
what is the best way to get them on and off?
aloha
steve
ps- my first post here, great forum
The collars are staked in 4 places which keeps them from falling off the bolt. Some people get a pry tool b/w the shoulder of the bolt and the top or the collar and can lever it past the ridge on the shaft of the bolt. If it were me I would take a very small grinder to the ridge until the collar can slide past the ridge. A dentist should have a grinder like that. ;) Jeff
mahalo (thanks) jeff
got it all done
was able to locate some tools to grind out the ridges and the slightly raised area on the bolt that held the collars :)
aloha
steve
7 mm h & r spacers
50 mm lug bolts
look is a slightly wider stance, filling out the flanks of the car better
i didn't want to go to 14\15 mm spacers and 60 mm lug bolts because i was a little concerned about unsprung weight, added stress on the wheel bearings, and the car looking like on of those low riders with the 13" wire wheels sticking out the sides :)
when i change my tires i am going to 225 in the front, and further fill out the stance and reduce understeer, this should complete the look
aloha
steve
