I was puting gas in the morning i turn the truck on and it started to miss fire bad i steped on the gas and it turn off turned it back on it started to shake it sound it when you pull two plugs off an engine steped on the gas for a while and it stoped its fine now any one knows what it is no fault code lmk please guys thanks
Could be coils
Let check your car with a PIWIS tester. I'll bet there are codes in the memory's, since the car is suffering with gearbox troubles too ( see your post on a Tiptronic topic ).
My car acted the same as yours. My wife said the car was stalling and then ran fine. Then later when we filled the gas tank the car started stalling again and we had it towed to a shop. turned out to be a fuel pump. I guess there are two fuel pumps in the car ( why i don't know ).
Regards,
Scott
testing fuel pumps
two fuses in the engine compartment 13 and 14. take one out and start the car if car works fine the the other fuel pump is out. take the other fuse out - car should not run...
