Twice recently when the 04 CS is cold (both times when leaving work after it sat all day) it won't move. I will start it and put it in gear and nothing. If I give it a little gas, it is like something engages and the whole car jerks forward (or reverse depending). No sounds or clunks, just annoying. Usually I let the car warm up a bit but you know sometimes you just wanna get going :). Transmissions shifts smooth otherwise once warmed up (it does have the hard 1-2 shifts when cold but the new control unit is $$).
Anyone else have any experiences with this? Thought I read a similar thread once but now cant find it.
I would check for fault codes first, and do a ATF change if the car looks faultless.
