Are there clips on the windscreen or just those mounted on the rollbar? I can't visualize how the windscreen attaches.
There are lever type devices that you use your thumb to open. Then snap the screen in and close the levers. Actually I think they close when you have inserted them properly.
This is critical or you next move could be retrieving the windscreen from the road.
If you have the rollbar inserts you may want to consider wrap-tying them with a black tie wrap. If you lean your seat back too far they will push out and you will leave these on the road as well.
Plus it keeps someone from taking them as easily.
