28 minutes ago, swywong said:
Hi Loren,
what is the rest procedure? I have two keys that is no longer working after key fob battery change. Do I need to reprogram them? If so, how?
Reset procedure: Reverse the battery for few seconds - then reinstall it correctly.
If that does not work then try re-programming. If that fails you likely will need new key (electronics).
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
