If i give a french dealer tsb number 2130 will they pull out the same French TSB or is it more complicated? this is probably question to RFM
Some TSB's concerning DME programming, environment related interventions and a small quantity of details are different. The TSB as mentioned is the same for ROW Europe, if your car is still eligible, your dealer can check that.
Thank you. The car is only 5k but there is an oily spot on front left cover panel. This is US version which keeps coming up with a service reminder (3k miles). Not sure what it is about but will change oil just in case and get dealer to clear reminder if they do this TSB
