Maybe one of you can clarify this: I have read through the many DRL threads and have found the whiteson.org hack that many have used.
The double relay 996.615.111.00 is also mentioned. Can the DRLs be activated just by adding this relay? Is the relay housing prewired for this relay?
Some threads seem to imply that all one has to do is plug the DRL relay in. :unsure:
Alex
Not all vehicles are wired for the relay. If not you can just install a universal daytime running light kit sold at your local auto store.
Thanks wvicary! :( Well, I checked the relay housing slots 6 & 7 in my car and they are empty, they have no female plugs so I must assume that the relay route won't work, only the 'whiteson' hack.
