Hi, all. On my 2001 2.7 with standard suspension and 17" wheels the rear wheels appear to have some negative camber (approximately 2 deg) and the front wheels appear to have 0 to 1 degree negative camber. Most other Boxsters I have seen appear to have significant front wheel negative camber. What are the camber spec's? TIA
The most you're likely to get out of the stock suspension is -1.0 degree in the front, if that. So on stock Boxsters you are not "seeing" more than that. If you lower the suspension you can get more negative camber in front. For the street, -1.0 is probably fine. For the track, more negative camber is desirable (-1.5 or even "more") for nice even tire wear and a flat temperature profile.
