Hello, I'm newbie here... ( My00 boxster 2.7 manual transmission)
I live in Seoul, Korea and I don'n speak English, Sorry...
I've got some problem, today cold morning I turn on the car and it's nomal condition, after few minutes flushing CEL light
I have a OBD2 reader and read that code P1219, P1577, P1578
I drive the car few mile, at low rpm(0 ~ 3500 ?) is good condition, but over 3500rpm is so bad.. It's like a bad MAF sensor
After replacing the MAF sensor the CEL comes back again...
bad DME? or bad fuel pump?......
Please help me.... T.T
Edited by haewooner
:welcome:
P1219 Accelerator Pedal – Signal Implausible
Potential cause: – Pedal sensor
P1577 Accelerator Pedal Potentiometer 1 – Signal Implausible
P1577 Accelerator Pedal Potentiometer 1 – Below Limit
P1577 Accelerator Pedal Potentiometer 1 – Above Limit
Potential causes: – Pedal sensor – Short to ground – Short to B+
P1578 Accelerator Pedal Potentiometer 2 – Signal Implausible
P1578 Accelerator Pedal Potentiometer 2 – Below Limit
P1578 Accelerator Pedal Potentiometer 2 – Above Limit
Potential causes: – Pedal sensor – Short to ground – Short to B+ Looks like it is very likely the accelerator pedal sensor.
  • 5 years later...
My '02 Boxster S just came up with the same set of symptoms. Did you ever figure out what the fix was?
See my post #2 above - it pretty much has to be the pedal sensor. Or a loose connection at the pedal sensor.
