hello
my car makes some funny rattling noise when the engine is warm (in the normal operation range). there are two distintive noises.
1. it sounds like thin metal sheets are rubbing each other. i suspect this is something to do with heat shielding material used around the muffler but i could be wrong but i am 100% positive this comes from the muffler area.
2. i also hear some knocking noise when 1. happens. i wonder if these two are related. i cant quite figure out where this comes from but as i reve the engine 2-3K, this goes away. this also may be related to the external vibration of some kind.
i dont hear any noise when the engine is running cool. this only happens as the engine gets warmed up.
my car has 14K miles. any idea?
