Looks like my starter is near to dying. When the engine is cold and I start the car then there is a very loud skeeking noice for a couple of seconds (2 or 3).
I suspect my starter. Anybody knows where this one is located?
Regards, frank
The starter motor is located under the intake manifold, on the rear side, between both cylinder banks ( in the V ).
Where exactly is the V on a flat or horizontally opposed engine? Just joking I knew what you meant but it was too good to pass up. They arent much fun to get to though. Make sure the battery is disconnected before proceding with removal.
Look on the passenger's side of the trans tunnel If I remember correctly since the TT's use air cooled style blocks I think it is actually on the outside on the Trans tunnel. Hope it helps
No engine removing is not necessary, just take off the intake manifold. Perhaps it is a opportunity to replace the water tubes in this area by light alloy ones if you have still the stock fragile plastic ones.
I have to apologize to porsche 356 I somehow thought you had a 996TT didn't think about the Cayenne. Guess I look like a jerk now Ha! I never put a starter on a Cayenne but it doesn't sound like much fun though. Let us know how it went.
Hi RFM,
Thanks for the help. ''unfortunately'' the watertubes were done 6 months ago!
I will bring the car to the shop. How many labor ours will this christmas gift be, roughly?
Frank
Jagman, no problem,I wasn't underneath the car yet (with the flashlight).
Are you getting the unit rebuilt? Many repair shops don't seem to know about bronze bushing used in the drive and often the noise will return in a short time.
