I need to retrofit the haedlight washers into my 1998 boxster to install Litronic.
I already know that there is no TSB for the headlight washers retrofit kit. When I bought the retrofit kit from Porsche therwas a harness in the box. But without a TSB I don't know where to put the wires. So has anyone of you a wiring diagram for the headlight washers. I suppose where to put all the wires, beside one wire that is yellow, it could be the one that gives the relay the information that the headlights are switched on, because the headlight washers only work when the headlight are on. It is so short that it has to be put somewhere in the near of the fuse box.
There is also a relay in the box, does someone of you know on which position the headlight washers relay has to be installed in the relay support.
Thank you
Turro
