hi
i just bought a 2000 model porsche boxster S, 5 speed automatic gear - tiptronic
the radio system is Porsche PCM and under the radio it is written Porshe navigation
the problem is that the whole system is dead and refuses to turn on, there is no error msg
what can i check? to try to figure out the problem
thanks
Edited by jijioz
hi
thanks
Check the fuse , I think its B9. but your owners handbook or the small card inside the fuse ox cover should confirm this.
hi
thanks
I think thier is a fuse at the rear of the unit as well but to check that you need to remove head unit and look at the back ?
thanks guys for the replies
i checked the fuse in the box and it seems ok
any idea how to check the one at the back of the unit?
Hi jijioz,
Were you able to find the problem with the radio? I'm having the same problem with my 2000 Boxter.
Missmonypeny
There is!!!!!
TRy this link http://www.renntech.org/forums/index.php?s...mp;#entry108664
It worked for me :renntech:
IT WORKED
i really thank u guys u rock
i found out after i followed the instructions that the fuse in the back of the unit is broken as well as a fuse in row E which refered to as info fuse
i replaced both and unit working.
i jst need to find the code and i am all set.
thanks
