Hi gang!
I have a 2003 996 C4. I have just finished installing a complete aftermarket sound/navigation system and I could not be happier with the results of that project! Unfortunately, I have not been able to enjoy it because my car won't start :( . Here are some important data points:
- Brand New Battery installed today
- Old battery had been disconnected for 4 to 5 days prior to new battery installation
- Key fits in ignition just fine. Turns OK.
- No prior electrical problems.
- Dash, radio, headlights, etc. work fine
- When turning the key and depressing the clutch I get nothing. Engine will not even turn.
- I get two system warnings: Anti-Roll Warning and Airbag warning which I had never gotten before.
- Tried to raise the roof and can't using the the switch.
- Checked clutch micro switch and its OK (saw this on a search on this site)
- Alarm seems to work fine
It is really frustrating. Any thoughts? Would love to hit the road this weekend!
I would dis-connect the battery and re-connect it. If
that does not
work then do the same but pop the stero fuse. Keep removing fuses
until the car starts. Sounds like you may have a short.
Paul
