I'm looking for a procedure with pics on how to change brake pads and bleed brakes; I'm tired of paying grease monkeys for everything :P I don't know where to find it. Thanks.
Edited by riley6
Check the 996 DIY area - 996 TT is pretty much the same. As a matter of fact the pics in that DIY are from a 996 TT.
Thanks. I will give it a try next time. I didn't see a brake bleeding procedure though?
Edited by riley6
You should not need to bleed when changing pads. If you want to renew your brake fluid (highly recommended every two years) then you will find a brake bleeding DIY in the same section.
Clutch bleeding on a 996 TT is different though - you will need Pentosin for that.
