Hello ,I found nice pair on ebay doing Cheap Item number: 110325747596
Can you just remove original lamps and replace w/ these xenons? Are they plug and play or do they require changes to computer/wiring/etc?
Don't even go there expect to spend thousands
by looking at the parts catalog its headlights, wiring harness and maybe relay that show as different part numbers depending on xenon or normal lights (there is also control unit for xenon which is screws to the headlight unit underneth
the thing you dont see is the need for a completely new vehicle wiring harness. each car has vin specific wiring
