I was given a Blaupunkt radio and don't have the code. Blaupunkt P09881B3966121 or Porsche 964 645 102X
There is a four digit number 1265 on the back. I used the first for buttons and entered the code. The number stayed lite. Do I need to hit an addition key?
I have a Blaupunkt decoder, but the serial number you quote doesn't quite fit. Here is the result I got by dropping the first zero:
I tried the four digit number that was on the radio, 1265, but nothing happened. Now the radio will not come up asking for the code. Is there a 24 hr reset after trying a few times?
Yes, there is a reset time, but I thought it was one hour. I believe that after 10 incorrect attempt the unit locks up completely, and you have to get it unlocked by a Blaupunkt distributor. Maybe you could get a manual for it which might confirm that. Is it the Toronto SQR46? I think there are places you can download it, but they all seem to charge....
Thanks....
