I have a 1998 Boxster coming up on 30,000 miles. I'm going to be doing the 30,000 mile maintenance myself, and I was wondering whether it was worthwhile to change the coolant. I have flushed the coolant on every other car I have ever owned every two years. The Boxster's coolant is coming up on 7 years old.
I guess my question is, how long will lifetime antifreeze last? Do you think I should change my coolant? Would it worthwhile to just drain the radiators and add a couple of fresh quarts?
I would not worry about it yet as long as it still looks good i.e. not dirty. Miles are probably more important than how long it has been in the car. If you do change it, change all of it and be sure to use the right type.
Looks can be deceiving, accuracy and quality of your anti freeze should be checked with an anti freeze hydrometer if in doubt.
I have seen ten year old anti freeze "Look" good.
